Vu v6 oil pump
Ingle94
27
Victoria, Australia
1994 VR 5L Ute
Any idea where the oil pump is in my vu v6? Google isn't the slightest bit helpful
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
In the front timing cover behind the balancer on the inside of the cover
luke10050
Australia
VZ Executive
If you want to check the oil pressure yourself, the oil pressure switch fitting is 1/4" NPT.
Remove the oil pressure switch and put in a 1/4" NPT to 1/4" flare/SAE/whatever with a schrader core in it and find a gauge and line. You should be able to measure the oil pressure with a gauge.
