slippergypsy221
Hey guys, I have a list of problems with my car
so lets get this going then shall we!
1. after planting it (doesn't matter under what condition) and taking it to redline (its auto) upon coming to idle the engine will start to feel like its gonna stall, like shaking and feels like its running on low fuel but this really only lasts for a few minutes and completely stops once the car is rolling at a cruisy speed (~25 km/h) or if i turn the car off for 10 or so seconds - i think it may be a fuel pump problem because>>>>>>>
2. sometimes on startup (also sporadic) it feels very...lets say heavy and stuggles to start, although it will always start, if i punch the pedal after startup struggle it still glugs a bit and feels like it does in problem one...would it be safe to say a fuel pump?
3. air bag light on dash - this annoying little light only seems to come on when i start the car and its cold, it will do its beep and turn off and then come back on and beep again and it will do this a couple times and then either stop or it will stay on for a bit longer and then turn off, usually it stops once the heater warms up - im thinking a connection somewhere is having a problem with the cold located near the fire wall or the air passages
4. drivers seat rocks - sometimes (if i sit in the right spot, which i seem to do a lot) under acceleration the drivers seat will rock back (due to inertia) i dont think its a problem with the backrest but a problem with the actual seat, i think a bolt is loose somewhere on the underside, but ive looked and cant see any bolts that could be the problem, has this happened to anyone else or do they know where the bolt is, if you give me a rough idea like 'front left between the middle and front of the seat' would be great
5. cigarette lighter keeps blowing fuses (even when nothing is plugged in it and nothing metal touches it) im guessing its a short somewhere, is this a usual problem? ive looked behind the dash and all connections to the lighter are fine, is it the lighter itself or a busted wire?
thats all the problems i can think of so far, hopefully you guys can help me C:
