VX 2001 "overheating"
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Johnnz, May 16, 2020 at 2:19 PM.
  1. Johnnz
    Johnnz New Member
    Bay of Plenty
    2001 VX Executive 3.8L
    Righto car "overheats" sometimes around 80-100 but the moment I let abit more gas in and go say 105-110+ it drops down again, or pull over for a min it drops to normal temp. Cant find any leaks anywhere could this just be a wonky thermo? Radiator fans? Not sure where to start
  2. Aussie Trev
    Aussie Trev Active Member
    Queensland
    2 by VX Acclaim Wagon Series II 2001 & 2002
    Turn the AC on and check that the thermo fans come on. Does it stay cool with the AC on?, assuming the fans start up with the AC that is. Is there any water loss? Inlet manifold gaskets get tired and it can start sucking air into the system via the gaskets instead of coolant from the overflow as the engine cools which can them lead to an air lock in the cooling system. This can show up as small amounts of coolant loss, which stays in the overflow bottle instead of returning to the engine. Whatever it is it needs seeing to urgently before the engine cooks.
    Johnnz likes this.
  3. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Its a process of elimination first be making sure your system is full of coolant, the next thing would be to see if the fans are working, once it warms up see if the top hose is passing coolant that would tell you its a sticky thermostat or not, then finally your water pump could be rooted.
    Johnnz likes this.
  4. Johnnz
    Johnnz New Member
    Bay of Plenty
    Im hoping its not this but its a possibility
  5. Johnnz
    Johnnz New Member
    Bay of Plenty
    Radiators still full top coolant hose full but just checked and 1 fan doesnt work. The one on the left doesnt spin with or without ac
  6. shane_3800
    shane_3800 Active Member
    places
    vr commo
    It's not a fan issue 100% if it was a fan issue it would happen below 10km not at 80-100km.
    I would first start with a radiator and engine flush to see if there's any crap in there. Then check if there's much crap stuck between the condensor and radiator if there is blow it out with an air gun.
    After you do these two things check how it operates.
    It seems to be overheating during highway lean out which sways me to thinking it's a system efficiency issue.
  7. BowTie
    BowTie Active Member
    VS V6 Acclaim
    Flush and replace waterpump and thermo and rad cap. These are dirt cheap.
    Last waterpump I swapped had no fins left.
    Once these are replaced, 90% of issues resolve.
    Then rad.
  8. shane_3800
    places
    vr commo
    If the water pump was the issue it would over heat at higher road speeds too. Water pumps when they loose the pump fins will overheat fairly quick at any road speed.
    Thermostat is the same it will over heat at any road speed.
  9. Trevor loves holden.
    vs commodore
    That picture showing high temp fan switching on so its reached over 114deg or there about, switch out the low fan relay and see if it fires up. The low fan should kick in at 104deg or when your A/C is on.
  10. shane_3800
    places
    vr commo
    Neither should turn on at 80kmh.
    BowTie likes this.
  11. Trevor loves holden.
    vs commodore
    PMSL they work of temperature not speed, hell sitting in traffic can turn them on. Better go back to trade school.
  12. shane_3800
    places
    vr commo
    Maybe you need to go back to school.
    A thermo fan is only capable of moving air at a certain speed I can remember how fast exactly but it's around 20kmh. At 80kmh the amount of air moving accross the radiator is far greater than any fan could ever dream to move.
    Thus at speed the temp of the engine should never rearch thermo fan cut in.
    This is why you always hear them cut in at drive throughs because there is no air moving across the radiator.
    If you can't understand this concept you best give up trolling people on car forums and actually go into the real world and do a tafe course.
  13. Trevor loves holden.
    vs commodore
    Lot of factors come into play why they come on during 80-100km per hour, following to closely behind traffic, towing extra weight, very hot day, unhealthy engine, transmission over heating, but never say never as that is wrong information, fans don't have to go as fast as there no air restriction in its path like a bumper bar. ;)
  14. shane_3800
    places
    vr commo
    You have absolutely no idea what you're talking about.
    A electic thermatic fan should never ever come on at road speeds of 80kmh if it does there is something wrong with the cooling system.
  15. Vin999
    Vin999 Active Member
    SA
    Vsedan
    factor in 45C air temps, AC on, trailer on rear with plus 1 ton weight, low gear/high revs, 1000 m slow rising hill climb, car full of passengers and stuck behind a semi with hot diesel air and you surely hope the factory fans are working even at 80 km without anything being wrong with the cooling system.
    Funny thing as well I noticed, you and tlh are just saying/argueing the same thing in a different way like opposite twins :eek: maybe your related ;)
