VX Acclaim auto about to go? or auto clutch?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by H.k, May 30, 2012.
  1. H.k
    H.k New Member
    VX Acclaim
    Hey guys, i own a Vx Acclaim V6 and recently when i accelerate off the lights i cant let the Rpm go any more than 2.5k-3k.
    if i accelerate a little harder the car doesnt gain speed but the Rpm go up and sorta sounds a bit like missfire.
    but when i ease of a little it will change to 2nd.
    Not too sure about these things but i have a feeling its the Auto?
    Help would be much appreciated guys! Advice? Diagnosis?
    Cheers fellas.
  2. HoldenOn
    HoldenOn New Member
    Newcastle
    97 VS equip, 4.2L stroker on its way.
    Sounds like the box to me, but I'm not a mechanic so hopefully someone else can give you some better input.
  3. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Have you checked the fluid level in the transmission? That sort of thing can happen if there isn't enough transmission fluid.
  4. H.k
    H.k New Member
    VX Acclaim
    yeah Trans fluid is fine, thinking it could be plugs. ***Hoping it could be plugs
  5. wylie27
    wylie27 Member
    VX Acclaim L67
    Check your plugs n leads as well. My vx acclaim would hesitate like a misfire and then get a massive clunk and then launch.
    Had holden over the car, they serviced the box, diffs etc and then found it was a lead that was failing.
  6. H.k
    H.k New Member
    VX Acclaim
    Yeah, ive had that before too but not as bad as this, thanks mate! Hopefully all works out. thanks for the help everyone!
  7. david dubbo
    david dubbo Member
    perth
    vx gen111 wagon
    mate when was the trany last serviced a change of fluid and filters might be the go
