Vx adjusting the tappets is it possible
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Leo.Bullterrier, Jan 22, 2011.
  1. I'm having our Holden Dealer replace the rear auto transmission seal and the tappet cover seals in our VX acclaim for $360.00 and am woundering can the tappets be ajusted in these modern engines or are they self adjusting. What else could be done while the covers are off that would save having the covers removed again latter.
  2. pablo
    pablo Donating member
    Was a 1997 vt v6 wagon
    Hydraulic cam followers are self adjusting. No provision is provided nor is it necessary to adjust. They are a 'throw away' item, like everything else these days!
  3. soop
    soop Banned
    Smithton, Tasmania.
    2003 SS Commodore Series II
    What Pablo said, what makes you think you might need to adjust the rockers?
    Or are you just wondering?
  4. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    $360, damn, they saw you coming. Local transmission placed replaced my rear seal for about $70, and the rocker cover seals that 5 minutes to install.
  5. Since I don't do the servicing myself I was just wondering what else I could ask to have done, when I had my baby in recently having the stop light switch replaced they said the tramsmission seal and the tappet seals need doing. I was quoted 1.5 hours to replace the tappet cover seals and I even looked in the manual and yes there is quite a lot to remove before one can even attempt to remove the covers. I'm more than happy with 360 and there work and service is near perfect, I even asked Ultra Tune and was quoted the same.
  6. The1
    The1 A Memcal a Day Keeps..
    QLD
    VS V6 Berlina Auto
    1.5hours to replace a rocker cover seals? youve been had. If youve got a socket set it's only unbolt, pull old seal off put new on and rebolt, nothing to it. No there's nothing else that should need doing while the rocker covers are off on a vx.
