SAMO-87
- Feb 20, 2005
- 300
- 2
- 18
- Age
- 34
- Location
- S.E Melb
- 02' VX Berlina 5.7L
Hi All,
I have been having troubles with the electric antenna in my series 2 VX Berlina.
Bit of background:
Antenna stopped working, will not go up. Checked all fuses, all ok.
Removed antenna to check, bench tested working fine.
Checked wiring to antenna, all seems ok. Trigger from head unit tested, all ok.
After cehcking wiring diagrams, I have established that the antenna is controlled via the BCM.
I removed the BCM and opened it up. A brief look at the circuitry, and all appears to be ok.
I am starting to think it will be a relay fault, on the BCM.
My question is, has anyone else experienced this, and if so how has it been fixed.
Thanks in advance!
Sam
Bit of background:
Thanks in advance!
Sam
