vx base idle set/reset?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Leanne, Mar 2, 2008.
  1. Leanne
    Leanne New Member
    Gladstone QLD
    VX SPAC Supercharged
    :thumbsup: hi.. has anyone got the base idle check/reset for vx supercharged com.
  2. minux
    minux Infidel Bear
    Posted in wrong forum. moved.
  3. convas
    convas Member
    Corvette z51 C4
    According to the service manual you need a scan tool to set the IAC to 0 steps then you set the base idle.
    I dont have a scan too so I guessed at getting it to 0 using procedure below.
    1 Turn the throttle stop screw until 1000rpm in Park on Neutral
    2 Disconnected the IAC.
    3 Turn the throttle stop screw until 450-550 RPM in Park or Neutral
    4 Shutdown engine and reconnect IAC
    5 Start Engine and run for 5 seconds
    6 Turn off Engine for 10 seconds
    7 Restart engine and check for proper idle.
  4. sp001in
    sp001in vyma100
    QLD
    VY ute
    where did you get this info from?
  5. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    the IACV reset itself at every ignition cycle, best dont mess with it if theres no issues
  6. convas
    convas Member
    Corvette z51 C4
    All but step 1 is from the service manual.
    Section 6C1-3 Service Operations
    3.11 Fuel Control System
    Throttle Stop Screw - Check or Reset
    That is true but the question was how to set the base idle not how to reset the IAC, the base idle is contolled by the throttle stop screw not the IAC.
  7. chargedvx6
    chargedvx6 Active Member
    VY SII HBD Calais L67
    Base idle would be virtual at best wouldn't it? The IAC is the tool of the ECU to keep the revs at the preset value in the tune. The idle screw is irrelevant really because to a point the IAC will over ride that setting anyway
  8. convas
    convas Member
    Corvette z51 C4
    Yes that is true, the base idle is the minimum idle speed you would see if the IAC is fully closed (0 steps) the ECU expects the base idle to be set to 450-550rpm and knows roughly how many steps it needs to maintain the desired idle speed, if the base idle is wrong, ie too low then you may get a bit of stumble when going off throttle until the ECU adjusts the IAC count, depends how far out it is.
    If the base idle is too high then the IAC wont be able to bring it down to the desired speed, ie if the IAC goes down to 0 counts and the idle speed is still to high.
  9. Doctor Bob
    Doctor Bob Grandpa
    Retired
    as i said dont mess with it if theres no issues
