VX Berlina Rear lights help
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by knighty92, Feb 12, 2013.
  1. knighty92
    knighty92 Member
    QLD
    SSV
    These are GLOBES not the full tail light housing.
    I recently bought an rear light LED globe off of ebay. I purchased 2x Red LED tail lights and 2x White LED tail lights. I need more to complete the set but i wanted to see which one looks better; the red ones are a nice deep red, the white ones are a really light red (yuck).
    Anyway, i installed the just before and i came into a problem. The globes that were already fitted (halogen) have two wires in it, i'm assuming one for the parker lights and one for the brake lights. My LED ones that i bought only have the function to be either ON or OFF. They don't dim, or brighten depending if the Parkers are on and the Brakes are initiated at the same time.
    I was wondering if I've messed up anywhere, or i just bought the wrong lights? They were listed as VX commodore rear lights.
    I can provide pictures if needed.
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    You need the globes with two silver knobs at the bottom, not one. Look at the bottoms of your old and new globes and see the difference.
  3. knighty92
    knighty92 Member
    QLD
    SSV
    Ohhhhk. So i dun goofed?
  4. SJM38S
    SJM38S New Member
    Tamworth NSW
    2001 VX Calais L67
    More than likely...
    Take a pic if you're still not sure :)
  5. knighty92
    knighty92 Member
    QLD
    SSV
    Doesn't it have the two nobs at the bottom?
    Is it just me, or do they look like it's been used before? lol.
  6. accentstencil
    Eschol Park, Sydney
    You appear to have the correct type of globe so I don't know what's going on.
  7. knighty92
    knighty92 Member
    QLD
    SSV
    Yeahhh, i thought so. I might re-fit them tomorrow and see if there's any change.
    On another note; Where the hell are the Reversing lights? I cannot find a way to access them at all, lol.
  8. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    See the little pins on the side. They are off-set. Make sure you put the globes in the correct way.
    PS. No need to post this subject 3 times.
