Vx berlina series 2 squeak
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Mattie, May 13, 2020 at 12:19 PM.
  1. Mattie
    Mattie New Member
    Hatton Vale
    Vx Berlina Series 2
    Hey guys how are you I have a squeak at very low speed and can hear it quite well when just rolling coming from the front
    Thanks Matt
  2. MiKExAUS
    MiKExAUS Member
    Sydney NSW
    VX SS A4 Series II
    Hi, need more details. constant squeaking without going over bumps? please be more specific
  3. Mattie
    Mattie New Member
    Hatton Vale
    Vx Berlina Series 2
    Don't hear it over bumps only at very low speeds around 30-20 or can hear it if put in neutral and push it,has had all the front suspension replaced as well as new struts and springs and the bush and bearing on top of strut.
  4. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    brake pads dragging?
  5. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Hard compound brake pads, is it constant or on and off, could be a buckle rotor, only other thing wheel bearing.
  6. ant797
    ant797 Active Member
    bunbury
    vy s
    Try turn the aircon on see if the squeeks in neutral could be the belts squeeling under a certain load or just rev it slightly in neutral
  7. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    Tail shaft in the back of the Transmission,
    Common on VX's
    My 1999 VT2 Berlina Sedan, and 2002 VX2 Berlina Wagon did the same,
    just turned the Radio up a bit louder.
  8. Mattie
    Mattie New Member
    Hatton Vale
    Vx Berlina Series 2
    Thanks guys will look into all suggestions brakes are only new bendix generals and new rotors thought might been a warped rotor but they where fine its only at very low speed otherwise don't hear it
  9. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    Brakes don't squeek when rolling, unless they are worn out.....Obvious they're not.....If your rotors were warped at the front, you'd get a rock or vibration through the steering wheel under braking....If the rears are warped, you'd get a pulsation through the brake pedal, under braking
    If the squeek has just started since all the front end parts have been replaced, re-grease them all....It's a common issue I strike, when people have replaced front end parts and a squeek develops...
