VX boot won’t open
BraydonHallows
VX Equipe S2
I’ve tried everything to open it, the cable in back seat won’t open the boot, neither will the key, I’ve got a mate to sit on the boot whilst I’ve clicked to key and also tried open it whilst I’ve clicked the key. Not sure what else I can do! The boots full aswell so no access from inside
lout
60
Langwarrin Victoria
have you dropped the rear centre seat
and try to remove your stuff
krusing
Melbourne, Bayside
There should be a Yellow pull handle to the left in the boot of the fold down centre seat, that should unlock the boot lid.
[It maybe hidden by the boot lining on the back of the back seat on the drivers side]
If the above doesn't work
Its most likely the Solenoid, and/or Arm/Shaft from the Boot Solenoid to the Boot Latch,
https://www.ebay.com.au/itm/Genuine...867840&hash=item288d33b87c:g:2DoAAOSwnKFeKnSX
Probably broken, common item as they get older, or how much they get used, its probably snapped due to wear & tear
Remove the contents, or push it aside, crawl into the boot, and carefully remove the boot lid lining,
And manually unlatch the lock.
