Vx bump stop
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by jordazbro93, Nov 11, 2012.
  1. jordazbro93
    jordazbro93 Banned
    wonthaggi
    VX Executive S2
    Hi I was was wondering if I take rear bottom bumps stop rubber out it will lower it abit my friend said it would ?
  2. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    No it wont lower your suspension. But if you take 'em out it will lower it for good if you hit a decent bump or pot hole. The bump stops are there to protect your car from
    bottoming out. For god's sake don't take 'em out.
    See this site.
    What are Bump Stops? - Suspension Bumper Stops Info Guide
  3. nitrowarrior
    nitrowarrior New Member
    East Gippsland
    1997 Vt GTS Build 78
    Not a good idea...........You need to listen to the first reply....Bump stops are there for a GOOD reason........bendy breaky time if you dont listen... ;)
  4. Nut Kracker
    Echuca Vic.
    VT SS 304ci (195i)
    I'm sorry, but your friend doesn't know what he's talking about.
    The ONLY way to lower your car is to get a proper kit to suit your car. Other ways like chopping the springs or heating them will just degrade
    the integrity of your suspension. Not to metion it is highly illegal and very dangerous to you and to other road users. If you are intent on lowering your car, save your cash and get it done PROPERLY.
  5. mpower
    mpower Well-Known Member
    As above a bump stop is there for good reason and will not lower the car anyway.
  6. vx_commodore
    vx_commodore Member
    Sunshine Coast QLD
    VX Commodore 'S
    It most certainly would lower you're car.
    1 maby 2mm, Visually unnoticeable.
    Not worth the trouble.
    Lowering spring's that will lower you're car propley are very cheap.
    Not worth doing it any other way.
    It's good that you asked first before you went ahead and did it.!
