VX Charging light comes on then gauges drop
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Batesman, May 13, 2013.
  1. Batesman
    Batesman New Member
    Wagga Wagga
    VX Executive
    VX V6 , Charging light comes on after starting, then Abs warning light, Then gauges all drop? Battery is new, Alternator or electrical?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Alternator, voltage regulator. Measure the voltage at the battery with engine running, should be around 14.2. Anything much lower or higher is no good.
  3. ashbox
    ashbox back in black
    The Car
    something black
    Agreed, alternator related
  4. franklinfrog
    franklinfrog Member
    VY SS Wagon 5.7 Auto Wikid Postie Bike
    Alternator, replace regulator on back or whole alternator. You can get a good regulator from the wreckers cheap. It'll be putting out an unregulated voltage, like 20V. Try putting multi meter on there to check. Small chance it's ABS module, but alternator more likely.
    Let's not go through this again, worth reading.
    http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/214492-puzzle-sherlock-holmes-commodores.html
    Similar:
    http://forums.justcommodores.com.au/holden-commodore-how-tos/191124-bosch-alternator-fix-replace-regulator-brushes.html
