VX Commodore Electrical
Jowewe
21
Melbourne area
Holden Berlina 3.8 Supercharged V6
Hey guys,
About 3 weeks ago I pulled my hand break slightly going around a corner (joking around with my brother) and about 10 seconds after that my dash beeped and some lights went off on my dash (abs, trac control, check engine, airbag and the oil light stays on for bout 20 minutes) I took it to the mechanic and he says the scan tool won't communicate sooo really donno what to do here... Don't know how pulling the handbreak can cause my car to **** up like this
I also disconnected the battery overnight to reset the ecu but not too long after drinking it the lights went back on
I appreciate everyone that stops replys to this post
H
harrop.senator
Guest
Unplug the abs module after leaving the battery un plugged awhile. If everything goes off but the abs and maybe the traction? Then it shows its in the abs system.
Jowewe
21
Melbourne area
Cool, I'll check the abs module out
BlackVXGTS
Melbourne, SE
You need to get your car scanned with a Tech2 (or equivalent) scan tool to identify the actual error codes that cause the lights to come on. Otherwise you are just guessing on the cause and potentially throwing money away replacing parts that aren't causing the problem. There are a number of forum members in Melbourne that may be able to assist you with your scan tools. Where in Melbourne are you located (suburb)?
Alternatively, since you have a V6, you should be able to display your error codes using the link below. Note that bridging pins 5 &6, give you engine/trans codes, and bridging pins 5 & 12 give you ABS codes.
Jowewe
21
Melbourne area
[/URL]
I actually took it to the mechanics to scan the codes so I assume that they would know what they were doin
BlackVXGTS
Melbourne, SE
They might not have the correct scan tool for your car.
BlackVXGTS
Melbourne, SE
Correct, ALDL is used for VR, VS, VT, VX, and VY Commodore V6 models.
mpower
busted abs module tends to drive other systems crazy. which would explain why the mechanic is having issues.
