Vx Commodore v6 5 speed has a pumping feeling at idle.
Silver spac
56
Mount Waverley
Vx Commodore 5 speed
Have changed all leads plugs dfi & coil packs. Does anyone have advise watch could be causing this
harrop.senator
perth
vr senator 355, vu 5 speed l67
Pumping?
Need a different explanation here as that's a confusing term.
Are the revs going up and down?
Shaking around bulk?
Like it still wants to go with the clutch pushed in?
Silver spac
56
Mount Waverley
Pumping?
It is like a throbbing. / pulsing doesn't matter if the clutch is engaged or not. Revs do not change
harrop.senator
perth
Can you shake the motor bulk by hand?
Has it been using any coolant?
What did the plugs look like you just changed?
Has it been using more fuel?
Anything coming out the exhaust?
Silver spac
56
Mount Waverley
No you can't move the motor. Engine mounts have been replaced.
Plugs were well used yes using fuel nothing coming out of the exhaust. No using coolant
harrop.senator
perth
Sniff the fuel regulator vacuum hose off the rail if reeks of fuel it's probably the diaphragm inside and it's running too much pressure.
