VX Coolant hoses
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by delta, Oct 13, 2012.
  1. delta
    delta New Member
    Australia
    na
    Hey,
    Im not very car savvy. I have a 2002 VX commodore, have just had the heater tap replaced as it was leaking coolant, was running fine for a week, now i discovered that there has been coolant leaks, it seems to be excessive, i had a look where it was leaking from and it appeared that the hose running sorta under the radiotor has a crack. What is this hose called??
  2. DavesCalais
    DavesCalais Member
    VT Calais
    V8? V6? If they run low on coolant other parts deteriorate quicker. Prob just a bottom radiator hose
  3. delta
    delta New Member
    Australia
    na
    It's a v6. The hose seems thin like 1or 1.5cm thick
  4. Killr6
    Killr6 tutut
    Hervey Bay QLD
    BA XR6T
    Mate beat advice is, if your not to familiar with your engine, take to a mechanic ask for a pressure test and this will reveal any leaks the system has.
    And you can get it fixed from there, don't go backyard mechanic on your car.
  5. DavesCalais
    DavesCalais Member
    VT Calais
    Must be an auto then? Maybe a trans line they run to the radiator to keep the transmission cooler. Shouldn't be leaking coolant from there tho
  6. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
    Ok, everybody stop talking about helping, delta don`t learn anything about your car at all never attempt anything, just take it to a mechanic, in fact shut down jc and replace it with a big brand mechanic site, hey killa 6 wtf?????
    Seriously though go buy a repair manual for your car and get reading and save some cash.
  7. Cashman_309
    Cashman_309 Member
    VTII Calais
    +1 for taking it to a mechanic. Take it to whoever replaced the heater tap and tell them about the leak
  8. Killr6
    Killr6 tutut
    Hervey Bay QLD
    BA XR6T
    Are you serious?? The op is asking for advice you tosser.
    He is asking if he has a coolant leak on a forum. It's not like we can see the car, so the op's best thing to do would be to take it to the mechanic.
    Forum is better off without comments like that from you. Good stuff.
