vx cooling pressure problem
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by holdenmama, Aug 28, 2012.
  1. holdenmama
    holdenmama New Member
    cambooya
    vx holden commodore
    in january my car overheated coming up the toowoomba range. it was leaking heater tap. fixed that and fitted new themostat, than a couple days later a hole in the radiator. fitted new radiator,radiator cap and water pump to be safe. couple days later blew the top radiator hose.
    Now not even nine months later and i have blown the top 3 tubes and leaking water. i just finished fitting the 2nd new raditor took it for its first run and blow the ass out of the heater tap again.
    All air was blead out of the system each time i worked on it.
    Why would it keep blowing the cooling system apart?
  2. vx_commodore
    vx_commodore Member
    Sunshine Coast QLD
    VX Commodore 'S
    Headgasket?
  3. holdenmama
    cambooya
    vx holden commodore
    im gonna check engine compression this weekend
  4. holdenmama
    cambooya
    vx holden commodore
    there is no water in the oil or oil in water.no bubbling with radiator cap off.
  5. ben315vz
    ben315vz Donating Member
    Tamborine Mountain, QLD
    '05 Holden VZ Calais V8
    Have you got the correct radiator cap fitted? If it is a V6 it should have a 135kPa radiator cap.
  6. holdenmama
    cambooya
    vx holden commodore
    yes i have the 135kpa cap. it runs and drives great. never misses a beat. good power. just keeps killing the cooling system. i have had no other problems with this car in the since we bought it 5yrs ago. we put a new raditior in it then and never had a problem. it has done 360,000KM.
  7. matsingo
    matsingo New Member
    vt v6
    system could be blocked up alot of gunk in the head cooling jackets..id give a couple of goes with a radiator flush and high pressure air behind ya ....u got high kms and had cooling troubles in the past..if that engine has never had a proper flush (not just by a garden hose) but by high pressure im sure your jackets will be blocked up causeing over pressure in ur system...this is if you dont have a blown head gasket..and you have a brand new radiator in it
  8. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Id be getting the cooling system pressure tested to see if theres any signs of it leaking.
  9. holdenmama
    cambooya
    vx holden commodore
    ok compression test has been done on the engine
    cyl 1. 75psi
    cyl 2. 130psi
    cyl 3. 70psi
    cyl 4. 70psi
    cyl 5. 130psi
    cyl 6. 75psi
    why do i have low compression on 4 cylinders? Is my engine #@*ed?
  10. vx_commodore
    vx_commodore Member
    Sunshine Coast QLD
    VX Commodore 'S
    Could be
    Valve's.
    Ring's.
    Head gasket.
    But all the sign's are not the best.
    Due to the history, It may be worth wile just getting a new second hand motor.
    You will need to weigh up you're option's.
    Part's + labour vs SH engine + Fitting.
    When i had issue's with my old motor, Simular to your's, I opted for Vy motor, Then rebuilt it.
    Very happy with my choice.
  11. holdenmama
    cambooya
    vx holden commodore
    might have to look into changing it over to v8 if this motor it had it
  12. Tree cutter
    Tree cutter Tree cutter
    Mt Gambier SA
    VX Calais SuperchargedV6
    You can test to see what is causing low compression by blowing compressed air into the plug hole of the cylinder that is low. You need a fitting that screws into your spark plug hole that an air line can plug into. You turn your motor over until the cylinder you want to check is at top dead centre so the valves are closed and then you connect your air line. Then all you have to do is listen for where the air is escaping to. You can hear a leaking exhaust valve from the back of your exhaust. Leaking rings can be heard by removing your oil filler cap and holding your ear over the rocker cover. Take your radiator cap off and see if any bubbles are coming up to show a leaking head gasket too.
