MitchF91
Hi guys,
Had this problem for a little while. Originally was leaking too so I've replaced the inlet manifold gasket and over the last few months also the water pump, thermostat, radiator and top and bottom hoses.
For a few months I've been getting the intermittent temp spikes and drops, tried to bleed the system several times. Decided to take a new approach at replace the coolant temp sensor or the side of the thermostat housing, which has made no difference at all.
There are no leaks that I can see anywhere, and even when the gauge has read full scale I've never blown any coolant?
Ideas as to what it can be? I'm stumped.
