Vx engine oil leak
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by spokeless, May 28, 2011.
  1. spokeless
    spokeless New Member
    VX Lumina V6
    I've got an oil leak dripping from the front of the engine on the drivers side. It seems to be oozing from behind the power steering pump but is really hard to spot. I don't think it is valve cover gasket. It higher up than the oil filter. Definitely engine oil.
    Any ideas anyone?
  2. edals
    edals Well-Known Member
    Here
    VE Equipe
    Well My Guess would be the Rocker cover gaskets.
    Degrease the engine down, then have another go trying to find the leak. I think its only really that or the power steering pump that could leak on the drivers side thats above the filter.
  3. ])R@G()N
    ])R@G()N New Member
    VT
    If its engine oil, the First thing to Check is that your Oil Filter is tight..?
    if its not that theres really only one thing left that will leak engine oil around that spot the rocker cover.
  4. spokeless
    VX Lumina V6
    Thanks for the replies. I have made sure the oil filter is tight. I'll assume it's the rocker cover then.
  5. Kunu
    Kunu chasing the big 300!!!
    97VT SSsuper6(179rwkw),daily barina,2008 VE Clubby
    yep +1 to rocker cover aswell m8, give engine good clean down then have another look :)
  6. Cameron P
    Cameron P New Member
    Quakers Hill, NSW
    REDHOT VX SS
    mine is leaking slightly in the same area mate and it is the rocker cover
