VX equipe wheel wobble
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by c2105026, May 5, 2011.
  1. c2105026
    c2105026 Active Member
    NSW
    2000 VTII Commodore Olympic, 2012 Ford Focus ST
    Hello all,
    The saga of recommissioning an uber-low mileage VX I equipe continues.
    Latest issue is a steering wheel wobble that occurs at highway speeds. An alignment was done about 6 weeks/2500km ago. New Bridgestone RE92s were installed at easter, about 1000km ago. The brakes were a bit warped, however these were machined yesterday; before all this there was a tiny bit of steering wheel vibration, now it is more pronounced. Any thoughts? My first course of action was to re-do the balance and alignment (I have a free coupon for this). The front suspension has been looked at by myself and the place that did the brake machining; does not appear to be faulty.
  2. ch1mp
    ch1mp Member
    If you have a valid reason for requiring my locati
    VT S-Pack 3.8L Supercharged
    try the bushes next. torsion bushes are often a culprit. quick and cheap to fix too
  3. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    It sounds like more of a balance issue rather than alignment. Could a wheel be buckled?
  4. ch1mp
    ch1mp Member
    i would think that if a wheel wasn't balanced properly or was buckled then the whole car would shake...not just the steering wheel...i'm no expert on that but it makes sense
  5. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Ive never seen machined brake discs give a proper brake pedal feel or be completely free from warpage.Once brake discs are old and worn,they are never the same as new ones,even after being machined.Brand new brake discs can be bought these days so cheap that its not worth worrying about machining them.
  6. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    was the wobble there after the alignment? or after the tyres were fitted? sounds like the tyres r faulty, if they were out of balance the wobble wouldnt get worse unless a weight has come off.
  7. c2105026
    NSW
    To clarify - the car was fine after the alignment and new tyres. Biggest change was after getting the brakes machined. Driving today there was not the wheel wobble I experienced under heavy braking at highway speeds before the machining, so the external runout of the front brake discs must be minimal (rears were fine, apparently); i figure that the ventilation fins won't be lined up, regardless of how much the exterior was machined, creating a mass imbalance. hmm, methinks I should have got the discs replaced rather than machined. :(
  8. c2105026
    NSW
    wheels balanced for free, they were slightly off, seems to have helped, vibration is back to where it was originally. will keep an eye on it.
  9. c2105026
    NSW
    nup, viibration back again - got a free 4-wheel alignment and balance done at local bob-jane (it was an offer for buying a full set of 5 tyres...) front end alignment quite out (I do remember whacking a kerb....). See how it goes on tomorrows uni commute. The torsion dampers are not leaking and seem pretty solid, perhaps some play in the other end of the torsion rod where it goes into the control arm. On wednesday will get car up on stands and have a very good look at everything - bearings, shocks, bushes, steering rack, etc.
  10. philba
    philba New Member
    melbourne somewhere
    VT acclaim
    you say you whacked a curb, could be a buckled rim as accentstencil had previously suggested
  11. c2105026
    NSW
    On todays commute everything was fine - no vibration that could not be explained via bump steer, general feedback and steering kickback. Will see how it goes.
