Gabster118
- Mar 26, 2011
- 26
- 0
- 0
- Location
- Brisbane
- VX Berlina SII V6 3.8L
Hey all,
Recently I lowered the front of my car by about 45mm (rear 60mm) and also replaced the standard sway bar links with aftermarket 'S' shaped ones.
After doing so I have realised a very loud and definite knock/ clunk every time I go over bumps. It almost sounds as if the suspension hangs loose, and then when it hits a bump, compresses, hits something and makes a loud 'clunk' (This is most likely not the issue, haha, just an analogy).
What may be the cause of this?
Is it due to the lowered springs, ie. the suspension is compressing fully and hitting the bump stops? So I need new lowered front shocks?
Or may it be due to the new sway bar links. Do they need to be tightened completely? I left some movement in mine so perhaps they are causing this clunk?
Either way there is no issues with the rear of the car, its the front that simply makes this loud noise even over the smallest of bumps.
Any help is appreciated!
Thanks.
Thanks.
