Vx fuel gauge
Klerckinator26
Crayfish Creek
Vx Commodore wagon
A while back I had my fuel pump replaced and ever since then the fuel gauge is showing empty when I fully fill it up and full when it's empty any solutions
Ginger Beer
Dunnydoore
If a shop did it take it back
Dropping the tank is APITA
Ginger Beer
Dunnydoore
I did but they couldn’t work out the problem
1. You need a better workshop
2. If it worked properly before they dropped the tank I would say they stuffed up the wiring during the install and now will not accept their mistake, make a complaint to "fair trade"
https://www.fairtrading.nsw.gov.au/
3. What did they do to diagnose the issue that they "couldn't work out"?
4. You need a better workshop
Or;
E = Enough
F = Farkinneedpetrolsoon
Or;
Set aside a day for you and another to drop the tank, dropping these, without a hoist, using jack stands, is rubbish, but it can be done on a hoist in 2 hrs, well, that's how long it took my joint to replace my fuel pump
Does you low fuel light come on when 100% full, or near empty?
I'm no auto elec, but in my uneducated over opinionated opinion, it sounds like the wires have been swapped around, maybe
lout
60
Langwarrin Victoria
probably fitted vy series ii pump/sender
Klerckinator26
Crayfish Creek
Vx Commodore wagon
Or;
E = Enough
Or;
Changed the fuel sender and still didn’t help
lout
60
Langwarrin Victoria
must have put the arm on back to front
is that possible
H
harrop.senator
Guest
Reverse the polarity on the sender wires.
I dno if could be a vy 2+ sender or the wirings set set at the plug. All I remember is when I fitted the vy 2 harness to my vu I had the same issue so reversed the sender wires.
It's that simple , can't believe the workshop had no idea how to fix it. Find another one lol.
