Yeah I have no life so replys are usually quick
haha fair enough but at least having know life means u can help someone with a problem
update on my problem:
still sounds like its got a lumpy cam
error codes: 12 all is good =S
plemem chamber seal = sealed and oiled for a good seal.
all sensors are pluged in and cheaked for problems (i also cheaked the length of the pin it the iac valve)
all bolts and nuts are in right place and roughly correct tightness
i drove for 20min to see if the ecu had to make adujsments (i disconected the battery while working)
the bit that has got me confused is that its only at idle not a problem while under accelration and normal driving is unafected so im guessing it could be the throttle position
or it could still be an eletrical problem
im going to pull throttle body off again tommrow and see if i have missed something
good parts:
inside of chanber and throttle body is a lot cleaner
started to polish my chamber lid (starting to look good) =D
mitch
