After you have cleaned up the intake I would also fit a catch can, to help prevent the crap building up again.
QldKev
yer i thourght about a catch can but im not racing at all so i will save my money(and spend elsewhere =D) and just pull it off and clean every service as it only takes a little bit to do.
Throttle body is controlled by the throttle wire. It depicts how open, or how closed it is. I beleive (not 100% sure but it make sence), that this then comunicates with the computer to ajust fuel and such
yea true but i thought the tension on the cable was crontroled as there arnt mutch adjustments on it
dosnt matter now because the problem is
FIXED and i worked out where i stuffed up
while pulling the throttle body apart again and cleaning it again (more througher) i looked at a hose which i took of in the first place and wonderded what it was (i thourght it was a dump valve of some sort) then went to where it whent (under the plenum chanber and there was another vacum hose)
put the throttle body back togerther and back on this time connecting the vacume hose and
WOHOO IT WORKED
so know its all fixed and runs alot smother so im now a happy camper
now off to work -.-
thanks for your help
mitch
