Vx l67 swap no crank
James867
Vx l67
I've done a swap in my vx put a l67 from a vt running vt ecu with vats disabled from mace got it linked now the problem is won't crank but starts fine bridging pins 5 and 6 any ideas?
lout
60
Langwarrin Victoria
have you measured voltage at the other relay pins to see what is missing when you attempt to crank
_R_J_K_
Zenki S14
Did you get Mace to send you a VT memcal or a VX memcal?
lout
60
Langwarrin Victoria
a relay will require coil positive, usually from fuse
coil negative usually from ecu
i assume you have checked the neutral inhibit switch
James867
Vx l67
Yeah bud changed the inhibitor switch today also new key head and programmed that still no crank but cranks and fires when bridged
_R_J_K_
Zenki S14
Did you try contacting Mace?
James867
Vx l67
I'll be contacting them during the week I wanted to check a few things first so crank angle senors fine new key head new inhibitor switch checked over all wiring and bolt ons all fuses under the bonnet and inside are good it's a pain I'm wondering now if it could be a faulty ecu from the vt l67 might try chase a complete vx one from the wreckers ecu bcm and key fob been quoted $330 for the lot nothing in ebay I'm stuck at the moment
lout
60
Langwarrin Victoria
crank sensor will not give no crank
check what is missing at start relay
