VX LS1 thermo fan plug replacement
st3r3otyp3
Donating Member
VX HSV VX SS
Hi, I've noticed 4 pin my thermo fans plug has gone very brittle and needs replacing, my question is what AMP universal plug can I swap it to I've looked at a Narva one and it's 20amp but I feel it's not enough do I need 30, 40, 60?
07GTS
Australia
VEGTS BUILT BLOWN E85
check what the fuse is for the fans, then when u are doing the plug make sure the terminals are crimped good as to not cause connection issues
  • Like
Reactions: Lex
BlackVXGTS
Melbourne, SE
Looks like you might need a 30amp or maybe a 60amp connector (from the Holden VT/VX Service Manual):
Fu Manchu
Get off your phone when you’re driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8, & ya mum.
Use a 30amp Deutsch four pin plug.
Each terminal is rated to 30amps so should work well.
You will need the special crimper for Deutsch connectors.
They are better connectors than those used by Holden.
Eg:
