VX manual ecotec into vs shell
Krusty2011
whyalla
WK CAPRICE, VS Commonwhore
Hi guys
Basically i have a vx ecotec donk that is manual. i have a vs shell i want to put it into for a daily/work car. can i use the vx ecu and loom. is it plug and play or is there more to it? like changing connectors and re wiring?
Thanks for your help
_R_J_K_
Zenki S14
If you're using the VX tail shaft, you'll need to have it shortened or pick up a VS S2 manual tail shaft (T5 tail shaft might work, not sure). The ECU might be a problem due to VT+ needing to have the BCM linked to it to work.
Not sure on the loom.
Head over to delcohacking.net, they should be able to give you a good run down on the ECU side of things. From what I have read, the Getrag uses the same VSS as the 4L60e, so all you need to do is get an auto VS ECU with a Getrag tuned memcal (which somebody should be able to mail tune for you for not much).
They'll also have a bunch of wiring diagrams for various looms.
