Vx N/A V6 Ecotec Rough Engine Diagnosis
Gw33dz
New South Wales
VX S Pac S2, VX S2 Acclaim Wagon
Yeah i used new bolts torqued to spec in sequence. It started running rough after a cold start, that's why I started replacing stuff/ head gasket.
It had an exhaust manifold leak on both sides (snapped stud each side), i replaced the studs, used manifold gaskets and maniseal, but the left header has a crack in it, and the flanges are leaking because i couldn't tighten them up properly, will get a long shank socket to nip them up today. Maybe it is O2 sensor related. Hope so that would be an easy fix.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Did it make that noise as well before you pulled it apart?
I'd be checking that the rockers are seated correctly on the push rods.
Gw33dz
New South Wales
Yeah, i don't think it was as loud a tick, but it was rough, like a couple cylinders weren't firing.
Today, i squirted a bit of throttle body cleaner down the pushrods.
Then i ran the motor up to operating temp and it smoothed out a lot, recorded some vid, excuse the weird vertical orientation, stupid phone did it, but you get the gist.
Be interested to see what you guys make of it.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Probably gummed up lifters.
Gw33dz
New South Wales
Thanks for all the help. I've got some lifters and pushrods on order, will let you know how it goes.
Gw33dz
New South Wales
Replaced lifters, push-rods and rocker arm bolts, now she's purring.
  • Like
Reactions: Lex
