Well I got into my car turned the key and nothing happened, tried a couple more times and it started and ran fine for the rest of the day. Next day went to start it, but this time it turned over but it wouldn't start. Again I tried a few times and it eventually started and worked fine for the next two days. So two days later and it won’t start at all, and it’s coming up with the fault codes: 740 756 757 1372 1860 These are mainly related to transmission, which I’ve had no problems with. I did fine one problem, why nothing happened when I turned the key, the starting relay was stuffed and it has been replaced, but the engine still won’t start.
not cranking Hey had a similar problem with my vt turned out to be the crapy eBay central locking buttons on the key. They managed to press down intermittently with out my knowledge would crank for half a turn then stop and then other times would work fine. In the end I just pulled them out
