VX Running hot?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by mayes, Feb 14, 2012.
  1. mayes
    mayes New Member
    1999 VTII
    Hey guys
    Ive got my mates car at my place while he is away, there is a intermittent problem where the temp guage will skyrocket and starting sreaming HOT for a couple of seconds and then go back to normal. Any ideas what is causing this? I have checked and topped up the coolant level, and there aren't any leaks. I plan to take it in for a service next week, but would love a heads up beforehand if anyone has any ideas. Thanks!
  2. Ghost
    Ghost Donating Member
    Junee New South Wales
    Vs Commodore berlina Sedan 1996
    Start with the thermostat it may not be opening early enough and that's what usually causes that once the thermostat is open the water is flowing right
  3. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    Could be an air lock in the cooling system.
    In the top of the thermostat housing theres a screw. With the engine running at operating temp open this screw to bleed out any air, there should be a constant flow of coolant from here.
  4. Ghost
    That's possible I'll remember that I think I gotta but of air in my system lol
  5. Cameron P
    Cameron P New Member
    Quakers Hill, NSW
    REDHOT VX SS
    When does it start to get hot? If there is no leaks at all then yeah thermostat possibly. Or if it's getting hot whilst idling then cooling down when driving it could be the water pump
  6. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    loose wiring connection to temp sender?
  7. Ghost
    Mayes start with the thermostat and air check then go up to eletricals from there
  8. mayes
    mayes New Member
    1999 VTII
    Yeah like i said im getting it serviced next week (might even bring it foward to end of this week) so ill let them have a look... but nope no visible leaks, gets hot while running...havent noticed it while idling, but i dont let the car sit there idling too much. Will check back in when i know more.
  9. mayes
    mayes New Member
    1999 VTII
    Hmm so...I had it serviced today
    All that he found is that the coolant needs to be flushed and replaced and the radiator cap isnt holding pressure... this sound about right? or is there more to it
  10. Ghost
    Yep that sounds right
  11. RiCeY
    Australia
    If the cap is faulty it will bleed coolant into the overflow but not pull it back when it cools so you end up with low coolant and overheating.
    Just go buy a new cap, top up the coolant and see how it goes.
