Thanks i did it.
Removal the rear seat via the black pull tabs
Undo the bolt under the rear seat back
Lift seat section out
Take out Plastic clip
Take out the arm handle up on the plastic trim
take out the screw over the C piller
Lift out.
Thanks for the reply. I have a feeling that it might be a broken spring.Could be a simple fix.belt may just have a twist in it,or the top hanger is dirty which may stop it from retracting properly.Worse case senario is that the retractor unit has a broken spring,which means a new belt.Hope that helps.
The seat belt is out to it's full extent and it does not feel like there is any spring tension, if you get what I mean. It's not like sometimes when a seat belt gets stuck and you pull it a bit you can feel the spring trying to pull it back.If you can pull the whole webbing from the unit,you find that the plastic around the shaft may be broken aswell.That's not good either.
