VX Series II Stock Front Speakers!
entourage88
VX Executive S2
Hey guys, i was just wondering what the size of the stock speakers in the front doors of the Series 2 VX Exec's are.
Are the 6" or 6.5"?
I have been given some decent pioneer 6" speakers and if there the same size i can just swap them straight with the stock ones yeah?
Thanks
valakis_vx
The Juggernaught Bitch!
Knoxfield, VIC
VUII Maloo R8 M6
i think their 6"?
but the biggest you can go is 6.5" :)
entourage88
VX Executive S2
ahhk, yeah i just want to swap them straight over using the same wiring without having to cut anything out of the actual door.
that should be fine yea?
thanks
valakis_vx
Knoxfield, VIC
VUII Maloo R8 M6
yep that will be fine, thats what i have done
Torquative
Sports Economy
VE SV6 3.6L SIDI 6sp
yup
VX is 6"
people put 6.5" in but you need to modify the speaker pods, and as I found out that doesnt always work in yoru favour. I wish I had stuck to 6" speakers now because my 6.5" rattle against the speaker pod with bass.
6" = easy as!
TMM
OEM+
VIC
VY Berlina S2
6.5" inch is fine, you'll just need a dremel to cut the hole bigger. Make some gaskets from 3mm closed cell foam to sit between the speaker and pod. Perfect seal and no rattles :).
Zeussy
SSM11K
Central Coast
Gen-F Clubsport, Rodeo 2.8 TD 4x4
^^^ And incase you don't have a dremel, like me.. unfortunately! You can just use side cutters, or pliers and cut/bend/snap a little bit out at a time.. Take you time and do it neatly, end product will be fine..
And double sided tape works well, had some in the garage, so I gave it a run, and NO rattles!!
GILLO
Western Suburbs, Victoria
98 VT Berlina
Hey guys I have a VT berlina and was wondering if you chuck in some aftermarket speakers like 130 Watt speakers for example, would you actually gain much out of the speakers if they are powered off an aftermarket head unit that is 4x50 watt? I was given some Sony speakers and i plan to put them in the front doors but i dont know if it is really worth it and i dont plan on buying another amp just for the speakers. If anyone can help that would be great
cewing
Castle Hill
VE SSV SWAGON
I believe the newer speakers would sound better, but are running at nowhere near they're potential.
Move to car audio forum?
valakis_vx
Knoxfield, VIC
VUII Maloo R8 M6
any speaker is better than those paper things in the doors lol
