vx speedo
pma
nz
S2 vX 2oo2 5PoiNT7 A4 WheeLie BaRS FLuFFY DiCe
my speedo crapped out, would a replacement from another VX slot right in or does it need to be married in?
lout
60
Langwarrin Victoria
if you replace cluster your odometer will not be correct and may need airbags, tacho etc recalibrated
try to find a same model with similar km's
pma
nz
just curious .. but how does airbags, tacho etc have to work with similar mileage?
lout
60
Langwarrin Victoria
afaik the speedo is not a separate component in the cluster
EYY
VS Statesman
Just find a cluster from a car with the same specs as yours with similar mileage (that is, same number of airbags, pretensioners, engine config, body type and tank capacity) and you can fit it straight in.
But if you have the tool to change the config, you can get one from v6/v8/sedan/ute/wagon etc it doesn't matter. You cannot change the mileage on a used odometer though.
pma
nz
cheers fellas
