Vx srs airbag light
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Madz15, Jun 12, 2018.
  1. Madz15
    Madz15 New Member
    VX Executive VL Executive
    Hi everyone, i just need help with something. My vx keeps throwing the airbag light and code on the scan tool 247, i think. I was just wondering what do I need to replace to fix it? Thank you
  2. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    which scan tool are you using
  3. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Here you are:
  4. NeddyBear
    NeddyBear Veteran Mountain Biker
    Queensland
    2004 Subaru Outback 2.5 & 2002 VX II Acclaim
    A good place to start is the steering wheel clockspring and the censor box under the CD holder.
    After having a Kangaroo go down the side of the Acclaim our light was on for around 4 years and that was with several visits to Holden (insurance claim) and they could not correct so I gave up. After replacing both of these parts the light is no longer on.
    Madz15 and RiffRaffMama like this.
  5. vx_commodore
    vx_commodore Member
    Sunshine Coast QLD
    VX Commodore 'S
    More common to be the clock spring in my experience. However I have used a continuity meter on an apparent faulty one and could not find a break in the ribbon cable. Spun it around but remained constant. Yes was on the airbag not horn or radio controls.
    Ended up finding out it was not the original cluster in the car. I reset it but kept comming back seconds later. Got the right cluster that fixed it.
    Pull yours out and test it. Don't always assume 'the one from the wreckers' is in new condition. Played this game a few times.
    Madz15, RiffRaffMama and NeddyBear like this.
  6. RiffRaffMama
    RiffRaffMama Member
    Just Follow The Sound Of The Banjos, SW Vic
    V̶X̶ ̶B̶e̶r̶l̶i̶n̶a̶ wrote off 19/9/18 VT Berlina
    I've had the same problem with around half of the commodores I've owned. See my pic? I actually had that printed as bumper stickers and I sell them on ebay to a legion of screaming fans. I've stuck one on every one of my cars regardless of their airbag light status. The VX Berlina I'm driving at the moment was roadworthied about a month ago and the clock spring was what fixed it too. Had to have the light reset at the mechanic though, it doesn't go off by itself.
  7. Madz15
    Madz15 New Member
    I'm using Snap-on's scan tool
