Vx ss 6.2 ls3 conversion
Discussion in 'LSx Development and Modification' started by VX SS 340 HP, Feb 2, 2011.
  1. VX SS 340 HP
    VX SS 340 HP New Member
    Chinchilla Qld
    VX SS LS1
    Hey Just wondering weather any one has converted there LS1 equiped Commodore to an LS3 just wanted to get some info on what i need to change i.e (gearbox, wiring and fuel system) also what sort of coin am i going to be looking at for a brand new motor
  2. SirNemesis
    SirNemesis New Member
    Geelong, VIC
    WHII Statesman
    About $8k for the motor + knock sensor extension + map sensor extension + 90mm cable throttle body + crank/cam signal converter + injector adapters.
    Budget about $10-11k if you are doing the job yourself. Around $14-15k for a workshop.
    Whatever gearbox you have now will bolt on and work, but if its an auto it might not last long. The factory fuel system will keep up with a standard cam LS3.
  3. cracker
    cracker New Member
    sounds good in theory but if you do the sums its pretty crap.
    power vs effort vs cost
  4. cpbait
    cpbait New Member
    vy ss commodore 5.7ltr
    imagine what an ls1 could be like with that 10-15k spent on it compared to a standard ls3.
  5. VX SS 340 HP
    Chinchilla Qld
    VX SS LS1
    HMM thanks for the ideas and the help im at the point were im not to sure weather i want to keep my LS1 150 000 klm on it and rebuild it with tuff internals or start fresh with a brand new motor weather it be LS1,2 or 3 and go with a N/A setup or Forced Induction...either way its a big decsion that im not in any hurry to make quickly i want to way up all my options and work out which is best for my budget of about 10k to 15k....Also Reliablity is a big part in it as my nearest decent performance shop is 300klm+ away...And Simplicity as majority of work will be done by me...im open to any ideas although at this stage im leaning towards a turbo setup...any HELP would be apprecaited
  6. Vt_vic
    Vt_vic New Member
    perth,Western Australia
    carless for now
    how much power are you looking for? the cammed l98 is a very popular combo for around 450rwhp
  7. VX SS 340 HP
    Chinchilla Qld
    VX SS LS1
    some were bettween 450rwhp and 600rwhp...but how hard would it be to put a L98 in a VX and what sort of money would i be looking at for a motor
  8. Vt_vic
    Vt_vic New Member
    carless for now
    for a workshop to do it its less than 10k and you keep your old motor
  9. Kingston_99
    Kingston_99 383ci HTV2300 blown LS1!!
    Cairns, Qld
    VY SS ute STROKED/BLOWN
    i'd go an bigger motor over the LS1. more cubes= BIG HP!!!!!
    if i knew the price for an short block LS3, i would have not wasted my money on a 12K blower for my LS1.
  10. ZaLumina
    ZaLumina New Member
    South Africa
    2008 Lumina Ute SS
    I just imported a LS3 in the crate for one of my customers
    We swapping out the stock L98 6.0L froma 2008 SS UTE and fitting the LS3 with all the groceries (cam, cold air, FAST intake etc)
    Will let u know when its done
  11. Kingston_99
    Cairns, Qld
    but in the end mate,
    i would rather a stroked LS3 over an F/I LS1. i made the mistake for not doing enough research. i'v just spent 12K on a blower ( thats just the blower) i still have to spend another 2.5K to install it. i also have to upgrade my cam, fuel system, and exhuast system. i will end up spending +15K after its bolted in.
    15K would get you one mean N/A LS3. i have seen short block LS3 for 7K. an stroked LS3 would have all the tourqe in the world over and built LS1.
  12. VX SS 340 HP
    Chinchilla Qld
    VX SS LS1
    So what sort of power would i be looking at roughly if i was to just cam, MAFless tune and flow the heads on an LS3...Also how would my auto gearbox go would it bolt up to an LS3 motor
  13. SirNemesis
    Geelong, VIC
    WHII Statesman
  14. BradSV8
    BradSV8 Nitrous Junkie
    VY SV8
    yep 350 rwkw is def possible with a cammed LS3. I have seen a cammed LS3 in a ve go 11.0 on the quarter so in a lighter vt - vz should be capable of a 10 sec pass with the right setup. It is not cheap tho but you can save a lot by doing the work yourself and researching before you buy any parts. Several places in the states are doing built 418-427 ci LS3 short blocks for around $4.5k to fully assembled long blocks for 8k.
  15. BEASTVFSSVR
    BEASTVFSSVR New Member
    In a house where it's nice and dry
    GEN-F GTS, VF SSV Redline, VX SS II, VN SS
    Hi
    Can anyone advise if this happened and if so how it went?
    I have a Series II VX SS 6M with 107,000km on the clock and in mint condition and I'm looking to do the same (looking at a 427).
  16. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
    LSA`s (new) are only 3k more than the LS3 @ 11k a piece, bit more dicking around getting it in but it can be done.
  17. enroh
    enroh Member
    Regional S.E. QLD
    VY SS UTE, 69 CAMARO!
    Yeah it's a relatively simple swap these days. Plenty of ls1 have been swapped for LS3 l98 ls7 etc
  18. NickGNB
    NickGNB New Member
    Sydney-North Shore
    VY SS Sedan, VY II Acclaim Wagon, Ford Territory
    Hey all, in the process of pulling the LS1 from my VY SS, (288,000kms, stuffed heads and oil pump) and have got a quote for an LS3 which will work for me. Just wondering if I will be able to use my LS1 aftermarket exhaust initially with the LS3 to keep budget down, and whether or not I will have to change the brakes to be legal?
    Any info much appreciated.
  19. 2INIL8
    2INIL8 Member
    VH COMMODORE 308
    Ive done an l98 conversion,your headers will bolt up no problem.
    Brakes stay the same although id get some good slotted discs and Bendix heavy duty brake pads as a minimum.
