VX SS front brake callipers
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by That Deaf Guy, Sep 21, 2019.
  1. That Deaf Guy
    That Deaf Guy New Member
    Bankstown
    VX SS
    i recently changed the brake pads on my VX SS. The front pads were not off a VX. After searching for hours I found they are off a VE. Anyway just today the right hand front calliper bracket snap when I hit the brakes hard. Firstly why would someone put smaller callipers on? Secondly is the bracket which joins the calliper to the hub genuine? Discs are 330mm. The calliper is damaged and I’ll need to replace it. Go back to VE brakes or? VX rotors are smaller I assume
  2. That Deaf Guy
    Bankstown
    VX SS
  3. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Well you should of did search first, just go to wreakers and get replacing parts. VE wont even fit your wheel studs you will have to change the whole front if its possible, to get a upgrade kit your looking around 2500+ unless you can find second hand. You can go up to a VZ in stud pattern.
  4. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    They make a kit, to fit VE brakes to other makes of cars.....Which appears to what has been done here....So it's rather obvious the wheel would fit from his car to the VE set up.
    What he does is his choice....Personally, I'd find out the cause of the breakage and decdie whether to change back to Vt to VZ brakes, or fix the VE caliper set up
    Lex likes this.
  5. That Deaf Guy
    Bankstown
    VX SS
    The VE pads are 114mm long while the VX pads are 180 (i think) so the VX have more surface area. Both twin piston. The bracket is cast alloy. If the VE callipers are better stopping then I’ll stick with them
  6. Trevor loves holden.
    vs commodore
    Fair enough I read it wrong I thought he put VE pads on a VX, yes I know their are kits to change them but why bother.
    That Deaf Guy likes this.
  7. stick3
    stick3 Active Member
    newcastle nsw
    vz sedan vs ute gsx1400
    the only brake upgrade i know using 330mm rotor and ve calipers was upc on ebay but they are now gone
    race brakes sydney sell brackets to suit ve calipers to fit vb-vz 440 a pair to fit any brand or size rotor or you can go back to vt-vz calipers and rotors
    https://www.racebrakessydney.com.au/miscellaneous-products
    Lex likes this.
  8. NeddyBear
    NeddyBear Veteran Mountain Biker
    Emerald, Queensland
    2004 Ford RTV Tray Back & 2004 Subaru Outback 2.5l
    Why not go back to the VX setup, cheap enough even as a fully rebuilt unit.
    We have the dba slotted standard size rotors fitted with the dba pads for towing the camper and they have plenty of stopping power.
  9. vc commodore
    south australia
    vc commodore
    Some people do it because they can......Or just enjoy chopping and changing parts around....Been like that for years and will be for years to come
