madsav
if all else fails mate, just goto holden ask to speak wit hthe head mechanic and ask him is that sound normal and or WTF it is lol, Another torque converter would set you back around $400 to a high performance 1 for around $1500
Not ture i have a maxidiag us703 scan tool it can read an delete codes.im sure off memory the LS! ecu can only be checked through holden using tech1 or tech2
that's exhaust noise probably a cracked manifold that heats up and seals when you give it some revs
google it common it's a common problem
Yeah they will charge you like 50 bucks just to read the code its a scam haha
Hi guys, I own a VT LS1 5.7 S2 1999, 270000k, and now I've finally got the ticking noise out of it, I got new hydronic lifter and new headers with high flow cats, well that made it worse, even Mark at Streamline Warner's Bay who I would recommend to anybody was just about out of idea's anyway knowing everything was new up the of the motor, I knew it had to be something simple and after pulling my hair out with frustration I went and got Lucas Heavy Duty Oil Stabilizer and Nulon Premium Mineral 20w-50, that was 3 weeks ago and it hasn't made a noise since and running how it should. Good luck.
