VX SS Manual, Revs drop to almost stall when disengaging clutch while driving
Nathaniel_P
Australia
1996 VS Commodore S
Hey guys, seems I've got a problem with the old girl, when driving along, any time i put the clutch in, the revs drop to an almost stall, jump a bit and then and then gradually struggle back up to idle, this seems to happen pretty much any time i take load off the engine, any suggestions? Cheers :)
BlackVXGTS
Melbourne, SE
How stable is the normal idle and at what revs? When were your spark plugs last changed?
Nathaniel_P
Australia
1996 VS Commodore S
The plugs are probably due for a change, regular idle is about 800-1000rpm, it's generally pretty stable with the odd shudder
dirty hands
ipswich qld
magna
service the engine then post back.. if no better
Nathaniel_P
Australia
1996 VS Commodore S
All sorted at this stage, PCV valve was rooted, running a lot better now
Nathaniel_P
Australia
1996 VS Commodore S
Nope, back again, service done, a bit of oil in the pcv hose and valve, only having the problem at low rpm when the engines cold, so cruising at 1500-2k rpm, take your foot off the accelerator and the revs drop below 300 rpm, sometimes even stalling, but then sometimes she's fine, any suggestions guys?
vr304
Auckland, New Zealand
2007 ssv manual
My vx ss manual does this too only occasionally tho in my case I suspect the dodgy mail order tune that it's got although I could be wrong
Nathaniel_P
Australia
1996 VS Commodore S
I was considering that, but i got it tuned and dyno'd like 2 months ago and haven't had a problem, it's only started over the past 2 weeks, is there anything that can throw out a tune?
Nathaniel_P
Australia
1996 VS Commodore S
The o2 sensors have 2 loops right? Could it be a faulty low end loop on a custom tune?
