VX SS Manual T56 - Tight Shifter
300kwv6
L67
Hi Guys,
Picked up an VX SS II 5.7 6 Speed manual.
The shifter seems very tight and nothcy. All gears work 100% just tight to move between them all. The old owner did a few mods to the car, so maybe one was a shifter mod?
Can I grease it up? or check it in any way?
What's the easiest way to get the console and gear shifter boot off for inspection.
Thanks
Cameron P
Quakers Hill, NSW
REDHOT VX SS
i drive a getreg 5 speed and then jumped into a clubby and also a vz sv6 with the t56 and it felt as you described.. so i'd say its normal
ryan101
whittlesea
vx ss
yeh mine is the same, i feel like u gotta put force to move from gear to gear! is there a way to loosen it up?
naf33n
go
The Shire
Supercharged VU SS
the vz sv6 has a different box to the v8s, its made by aisin or something like that,
in my ss the box is pretty notchy, sometimes hard to select reverse
TonyJZX
East Coast
Commodore M6
you can put nicer oil in it
in mine i often get 3rd instead of 1st
or 5th instead of reverse
but overall it's not a completely terrible gearbox
it just has to be that way due to the power handling, smaller weaker gearboxes for lower powered engines feel better
bencbh
Bathurst
Ve sv6 ute 08 manual
I have the same problem on my vt, real prick when's it's cold, Iv been told it's play in the shifter linkages,malwood has reco shifter assemblys for $225 I'm gonna get one I'll let you know how it goes
300kwv6
L67
As suggested it may just need a oil change with some good quality oil, and maybe thats just the way it is, plus its done high km's.
I never ever miss the 2-3 shift thats why I thought it had something done to it. You push it straight up (dont even have to go across) and its into 3rd.
I will investigate further.
Thanks for the advice :)
Jono Rice
QLD
VX 5.7 M6
Hey guys i tried searching for this but how do you remove the factory shifter? i need too replace the shifter as the shift pattern came off mine before i owned the car and now i need a road worthy. would i be able to get one from holden at all? The car is a vx ss 6 speed. cheers.
DLFHUB666
GIT 'EERRR DONE!!!
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
Sounds like you have a RIPSHIFT.
otter2183
Newcastle
VZ SS
Hi Everyone,
I had the same problem with my gear box. If you just have a stiff shifter, chances are the bushings and linkages are dry ie free from grease. My mechanic (Gilberts Maitland - Gilbert's Motor Garage. - 49331185 ) fixed the issue for $200.
It probably is a job the home tinkerer can do. I think there is a link somewhere on the forum to tell you how to remove the center console. This will give you access to the shifter bushes. Then it just needs a clean out and grease. Mine went from requiring significant effort to move the shifter to incredibly easy to move with almost no resistance.
