VX SS Manual to Auto Conversion
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by anarklov3r, Oct 6, 2011.
  1. anarklov3r
    anarklov3r Member
    2007 WM Caprice
    Hey Guys, got a chance to pick up a written off VXII SS pretty cheap (Paint stripper to front end and kicked in rear quarter). I'm not fussed about the body work, as i am capable of getting that fixed myself.
    Only thing is, engine is out of the car at the moment, as it was stripped of the manual box, drive shaft and diff. Looms, pedal box etc are still in the car.
    Car comes supplied with a Auto BCM, auto pedal box, Auto trans and looms. Would it be much hassle, considering the manual is already out and stripped, to swap in the auto box?
    All i need to source out is an auto drive shaft, and a diff (i've actually already got one, so im set there!)
    And, if it is too much hassle to do it at home, How much would a mechanic charge to fit an auto + engine into a car if i just get it towed there?
    Cheers guys!
  2. CRANKN
    CRANKN New Member
    A slow1
    easy job, tailshafts are same, just need to swap wiring harness over and get PCM flashed to manual
  3. ucwepn
    ucwepn America just kicked in yo
    WH statesman 5.7
    Mechanics charge by the hour for labour so you just have to find out how many hours it would take them roughly. don't go to a franchise mechanic like ultratune find someone reputable in your area. If you're in the nthn suburbs I can recommend a couple of shops who are very good with commodores.
  4. anarklov3r
    anarklov3r Member
    2007 WM Caprice
    Yeap, I'm in the northern suburbs. Apparently there are some hard lines or something to do with manuals? No idea... I'm even thinking of just buying a manual box and slapping that in...
