ComVX
VX Starting problem... all changed, what else? key?
I have a VX lumina 2002 same problem, changed starter, CAS (crank angle sensor ), crank pulley, battery, plugs, plug wiring,... cleaned and testet injectors, New FUEL PUMP, and still from time to time i get a problem starting my Car, it cranks the fly-wheel make a travel then asif it miss fires or something and doesnt run the engine, i leave my key for few secs take it out and try several times then itstarts, what else could be the problem??? any help?? its the first time here i hear about the KEY signal stuff, what does it has to do with that? the battery is new also... By the way it happened to me once when the car didnt start, later the key didnt work to close my doors, i said oh its broken or so, then of a sudden the next time i ran my car , it worked afterwards.. PLZ tell me what else i should fix to stop havin this ####in problem??? everything is changed, thanks guys..in advance
