VX steering wheel to VZ steering wheel Horn wiring.
MattaY[s2]
BEA5TN
Victoria, Melbourne
VX II Executive
Hi there,
I did this mod last weekend all went well except the wiring for the horn.. So I figured to leave it and figure out how to do it and come back. when I realized how easy it was I went to do it today but there is no "Clip" on the vz steering wheel for me to plug my other plug into.. So I figured I would get a ring and solder the wire to that and just find a screw and screw it on.... Problem solved right? .. But no...it didn't work... Can anyone help me?
Pic of golden clip i need.
How I have wired it.
How The ring looks.
MattaY[s2]
BEA5TN
Victoria, Melbourne
VX II Executive
I didn't have to touch any wires when I put a VY steering wheel in my VX, it was all plug and play. Not sure what the go is here.
You probably had the convertor connector or something... As I understand it you need to snib off the plug from your old VX horn pad and simply wire the positive wire to the plate on the VZ airbag and the earth to the steering wheel earth plate or w/e it is..
BTW Its really weird now i left it connected the way i had it without it working (god knows why) and i went to start it and coulnt turn the key (Steering wheel locked) so i finally fixed that but when the car started the interior light wouldn't go off? then I unplugged the wire that's connected to the ignition surround (where the light is) and it will start and turn off but the first attempt to start it it will start then go off, so i need to lock myself in the car then unlock it and then start it... wtf? lol
MattaY[s2]
BEA5TN
Victoria, Melbourne
VX II Executive
read this
https://forums.justcommodores.com.au/threads/vy-steering-wheel-conversion-vt-vx.93928
this is what happens when you start messing with the electronics in cars they don't like it, "cos it was all good then something changed" and they don't understand it
do the steering wheel controls light up ?
I don't know if your having a stab at me or not... but I will take it as you're not.. I understand the car is still getting a ground from something and I'm fair sure disconnecting the horn wires I put in would fix that. and i have no steering wheel controls in the car ATM there coming this week sometime. As i understand it though they should because it is different wiring I need?
EDIT
Also that is the guide I followed to do the conversion.
VX Exec
30
Wilberforce NSW
VX Executive S1
Sounds like your grounding something out... Check your wiring, and maybe call up Holden and see what they'll charge you for the horn clip
oska
vx custom 600RR
why would i have a stab at you?
i've just checked the wiring diagram and i can't see why the horn isn't working you've have it as it should be
check the fuse and or relay
