Vx super6 lifter noise and oil light on start up
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Brad_BlackL67Calais, Dec 8, 2015.
  1. Brad_BlackL67Calais
    Brad_BlackL67Calais New Member
    Rosebud
    Holden 3.8 supercharged vx Calais
    Just had engine rebuilt including heads but the guy didn't put new pushrods or valve springs in didn't realise for a few weeks, got new crow springs and chrome moly pushrods (pretty sure that's it) and thought it would fix it but still the same tried 5-40 10-40 15-40 oil there wih all but worse with thicker oil anyone got any suggestions? The old spring where very week just over half a cm short compared to new ones, was thinking maybe the idiot didn't replace lifters even though invoice says he did..
  2. Brad_BlackL67Calais
    Rosebud
    Got told I need a new crank angle sensor could that be the problem also sometimes when I start it blows smoke but it was/is running rich a lot of carbon in extractors :/ haha
  3. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    the oil light on start up isn't the normal warning lights that show up as pre checks when u start it is it? hopefully u haven't got that mixed up.
    assuming the oil pick up was all cleaned during the re build yeah? if so do u know what it was like before the rebuild?
  4. strgas
    strgas GRA = REAL HP
    lifter rattle on start up is normal as the oil pressure is low and needs to get from the pickup thru the oil pump oil filter thru the oil galleries etc etc . black smoke on start up could indicate leaking or dribbling injectors ? more seen on cold starts as the fuel sits in the head ports where as when starting hot excess fuel may evaporate with a hot engine .
  5. EYY
    EYY Well-Known Member
    VS Statesman
    Try 20w50 or 20w60. They're an old design and like slightly heavier oils.
  6. Turtl3
    Turtl3 Member
    W.A
    VX Calais V8 International
    Could always try one of the ryco 'high performance' oil filters that has the anti drainback valve and see if that improves things...provided they make one for the v6? I know they do one for the ls1 which is the z160he.
  7. Brad_BlackL67Calais
    Rosebud
    Nah it's not one when u first turn ignition on its as soon as the engine actually turns over, I was thinking it's sort of normal for some noise but also its worse with heavier oil was actually quieter with 5-40.. With the injectors I just got Remanufactured ones from mace but I did a pump a while back I'm thinking the people gave me a standard pump, supercharged runs a higher pressure I think. Okay that sounds like a good idea turtl3 I'll do that when I change the oil again, also am doing a flex plate atm due to a crack Aswell as torque converter and shift solenoids haha
  8. Turtl3
    Turtl3 Member
    W.A
    It makes sense to be worse with a heavier oil on start up as it will take longer to flow and fill the galleries. U will probably find that it will improve when the engine warms up to normal operating temp tho. They definately, DEFINATELY should have fitted a new oil pump with the rebuild. Just stick to running the recommended oil in it (10w40 i think). When i picked up my calais which has an ls1 in it, the previous owner had put 20w-50 in to try and hide an oil pressure problem
  9. Brad_BlackL67Calais
    Rosebud
    Yeah exactly I knew that was a reply to EYY haha and yeah it does of course and well it says they did on the invoice and new lifters Johnson hylift roller lifters it has high ratio rockers Aswell 1.9/1.95. I'm going to go back to 10-40 like u said and just get a decent brand mobil1 or Penrite
  10. Brad_BlackL67Calais
    Rosebud
    Damnn that sucks mate I had problems a week after I got mine all the pulleys went and just all general items like fuel filter spark plugs and leads hadn't been changed in ages just had oil and filter done a lot.
  11. Decicrate
    Decicrate Member
    BrisVagus
    VS L67
    The first thing I would be doing is putting a oil pressure gauge on it and looking at what the oil pressure is at idle then at higher RPM.
    Sounds like the oil pressure is very low
  12. wrx884
    wrx884 WA's ASR Rep
    Sounds normal to me regarding the oil light. It will stay on with just the ignition on but once you turn the motor over and it runs it will go off shortly after.
    It's when there is no light or the light stays on after you need to worry.
  13. EYY
    VS Statesman
    Keep in mind that a thinner oil will drain back more quickly than a thicker oil. I put 15w40 in mine once and it was extremely noisy. 20w50 is still one of the recommended weights in the manual.
    It might be worth replacing the sender if you haven't already. In any case, oil weights shouldn't really make a difference in one of these engines. They'll run fine on cooking oil lol
  14. Brad_BlackL67Calais
    Rosebud
    Actually I don't know why I didn't think of that haha very smart idea :) thanks then at least I can see if there is a problem and I will change the sender Aswell. I'm going to go thinner because it's just been rebuilt 10000 ago and I couldn't hear the lifters with 5-40 in so I'm going to go 10-40.
  15. Turtl3
    Turtl3 Member
    W.A
    At 10000 its definately worn in now, all the clearances should be good. Its perfectly normal for the oil light to be on with ignition, but i should dissappear within 2 seconds of the engine being started and running. It isnt mandatory to replace sensors with a rebuild. Because 1-sometimes the customer doesnt send them in for testing or replacing, 2-they can be very pricey to replace 'for the hell of it' 3-sometimes they test fine on the bench, but they can fail a short time later when back in service.
    In ur case i would get a new pressure sensor, stick to 10w40 and keep an eye on it
  16. Brad_BlackL67Calais
    Rosebud
    I've said it goes off after ignition is on for a second I am a mechanic lol I just haven't got experience with rebuilt engines not even a year since being qualified so yeah haha and I know it could be the oil pump even though I know he put a new one in I've heard a lot of bad things about he place I had it done at but after I had it done which sucks... The oil light comes on while actually starting the engine and the lifter noise.. I did have to do valve springs and pushrods cuz they didn't put new ones in broke a valve spring 2 weeks after I got it back n bent the original pushrod on that valve got hardened custom ones and crow springs now they where a cm lower than new ones very worn out in new engine not happy about that so it may just be that lifter.. Hopefully the 10-40 will be better anyways
    I will definitely be changing the sensor maybe they just have a lot of air in them from changing the spring because I pressurised the cylinders with air, may have just answered my own post lol
