VX V6 Rear CV Driveshaft - HELP
ultra_pikey
VR
Hi all,
Have a problem with my rear CV driveshaft. Got noisey, then lost drive.
Has anyone done this repair or knows how to fix it?
Any tips would help, as having a tough time removing it. :bang:
Cheers, Pikey
vt s
vt s s1
Fairlyu easy to replace.
There will be 6 bolts (from memory) connecting each end.
I think you will need a torque bit if i remember correctly.
Obviouslu car will be needed to be jacked up and just make sure if your replacing it that you put the new one in the right way, it should have a sticker on some sort of marking on it.
Hopefully this helps i will say im that my experience was only with a vy.
gsxrdan
Has this got a turbo?!
adelaide, southish
93 VP Excec; 95 II VR Equipe; 99 VT Exec
Hey ultra pikey, just done this on mine, after skinning three knuckles, i got my angle grinder and cut a 20mm piece off my 8mm hex key and stuck it in an 8mm socket - too easy!
ultra_pikey
VR
Cheers vt s and gsxrdan.
Will give it a try this arvo.
Pikey :)
