I didn't show how to change the rear shocks because I didn't change them.
My rear shocks aren't standard, they are KYBs that the previous owner put on.
I didn't think there was a need to show how to disasemble the the front shocks as it's only 1 nut to undo and then slide everything off remembering the order (see above photo). If people have got this far in the job, I'm sure they can work that part out.
Makes sence to me now that I've done them but when following this how to I was lost when it says "pull the old shocks apart"...
I didnt know where to begin and it didnt even say to remove the nut and leave the clamps on untill its pulled apart... (just a pic)
Just on the title it says "shocks and springs" not "Front shocks and all springs" So I was lost when it came time to remove the rear shocks. (but they were easy to cut out)
Also I didnt support the hub assembly with a jack, I just lowered it gently, Is there a reason I should have supported it? Would it damage it if I left it hang?
Other than that it was very helpful:thumbsup:
