VXii Front suspension/steering issue
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by MiKExAUS, May 13, 2020.
  1. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    That's why car manufactures put them in for or they would of left them off saving cost.
    Now the wheel Alignment is done don't worry about it, the weight will keep them silent long as you don't start going off jumps. When I put my castor bushes on as they were second hand Nolathane they had the left and right set up cabled tied so I was lucky, don't know if they added anything doing the alignment they might have.
  2. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    Leave it upto you to figure out where they go.....My suggestion isn't fit for this forum, especially where you are concerned
  3. Vin999
    Vin999 Active Member
    SA
    Vsedan
    You don't need them on the bottom, springs sits in slots in place on strut bracket.
    What was cable tied that you were lucky with ???? and why would you put on 2/hand worn bushes ????
  4. Vin999
    SA
    Vsedan
    Well you queried my post to OP when I was online last and since you’ve stated you’re a professional aligner it would be good to check/know if my aligner did a proper good job ??
    And would help the OP as well plus anyone else in the future since we have the same front end dimensions and you would have to have worked on many of these very common commodore front ends at your place of employment :)
  5. Trevor loves holden.
    vs commodore
    Each side was in order with L&R labelled, Why second hand, because they were 60 for the lot and in good condition, also because I wasted money on rubber ones which only lasted 3 months, Nolathane ant cheap new. Yes I understand every car alignment is different that's why after fitting new lower control arms and front radius bushes I got it corrected.
  6. vc commodore
    south australia
    vc commodore
    And metal moving on metal doesn't make any noise o_O
  7. vc commodore
    south australia
    vc commodore
    I don't know if the aligner did a good job, because I wasn't there, didn't do the job, haven't seen the report , driven the car or have magical powers to report on a car that I have no idea what it looks like....So if you use that car to bring me my motor, along with the alignment report, I can answer the question
  8. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Glad it ended up being alignment and you didn't end up going straight to pulling the rack out.
  9. MiKExAUS
    MiKExAUS Member
    Sydney NSW
    VX SS A4 Series II
    I think it was air in the Power steering lines that caused the issue - but an alignment after the work definitely made everything feel even better. Cheers
  10. MiKExAUS
    MiKExAUS Member
    Sydney NSW
    VX SS A4 Series II
    Thinking of doing rear subframe bushes and diff bush at a later stage. These two will probably muck up alignment in the rear again, correct? Any tips for these jobs? I think there are a few posts detailing the procedure with some issues about alignment of the subframe/cradle. Thanks again!
