VY 03 Calais vibration at 20-40kms
djwatson93
30
whyalla south australia
VY 03 Calais L36
Hey everyone
Just purchased a VY Calais 03
She has a bit of a vibration when accelerating between 20-40kms
The vibration is more pronounced the harder you accelerate betweens those speeds
Just had new tires fired and a wheel alignment and balance done today
The issue still persists
I've checked the transmission mount its still in good condition
But these engine mounts do no look to healthy
https://ibb.co/h8v5bfC
My old man said they look fine but he is nearly 70 now and I'm pretty sure this proves his eyes are getting bad haha
Any advice would be really appreciated,
First decent car I've owned and I plan to get it mechanically A1 and put some work into it
Thank you
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
Vibration under acceleration could be tailshaft/centre bearing/ rear gearbox mount/rear suspension bushes.
And don't knock your old man. I'm 72 next month.
He has probably forgotton more than you will ever know.;).
djwatson93
30
VY 03 Calais L36
Hahaha thanks champ I'll also check those things out
Yeah you're not wrong about that mate a lot to learn from the old generations.
losh1971
North Tas
VE Series I SS Ute
Agree with above the first thing to check is for cracks in the rubber bearing mount. If it is this, don't wait or you will trash the shaft.
djwatson93
30
VY 03 Calais L36
Alright I'll check that out after work today and have a little google on its location
Guessing it's just mounted around the tail shaft
djwatson93
30
VY 03 Calais L36
So I check the tailshaft mount bearing
It is basically new, must not have been replaced to long ago
You guys think engine mount could be the problem?
losh1971
North Tas
VE Series I SS Ute
Check your pinion angles if they are out due to sagged trans mount you can get vibes.
djwatson93
30
VY 03 Calais L36
Alright I'll figure out what pinion angles are
I looked at the trans mount and the crossmember for the mount looked ok but I'll give it another look
losh1971
North Tas
VE Series I SS Ute
Forget what I said to some extent, it shouldn't matter. You will have a centre mount that will keep the pinion angle ok anyway unless the car is lowered.
losh1971
North Tas
VE Series I SS Ute
There has been a few cases over the years where people have had the TS out of balance.
