VY Brake Check
neville8689
62
mandurah
VY Lumina
Hi Guys.
I recently did a wheel rotation on my '02 VY Commodore and had a look at the brake pads in the process. The pads I could see (on the outside of the caliper) had about 5mm of pad material left. I was wondering if any one would know approximately how long (approx km) these pads still have in them before replacement is necessary? All work fine at the moment, no squeeking or shudder. These pads have done about 80,000k's.
Thanks.
sp001in
vyma100
QLD
VY ute
Normally stock pads on normal use will get you 150,000.
5. SPECIFICATIONS
BRAKE FLUID
Type ......................................................................... Super DOT 4 Plus
BRAKE BOOSTER
Make ......................................................................... PBR
Type ......................................................................... Tandem, Vacuum Suspended
MASTER CYLINDER
Bore diameter (nominal)............................................. 25.4 mm
Crack point ................................................................. 3.1 MPa (stamped on master cylinder end plug)
FRONT DISC
Type ......................................................................... Ventilated
Diameter (nominal)..................................................... 296 + 0.0 - 0.2 mm
Thickness ................................................................ 28.0 ± 0.15 mm
Lateral Runout (maximum) ..................................... 0.04 mm Total Indicated Run-out (TIR)
Minimum disc thickness, requiring replacement ........ 25.0 mm
FRONT CALIPER
Type ......................................................................... Twin piston, sliding caliper
Bore diameter (nominal)............................................. 42.0 mm (each)
Front Disc Pad
Material.................................................................... Organic, non-asbestos
Minimum Thickness before Replacement............... 2 mm
REAR DISC
Type ......................................................................... Solid
Diameter (nominal)..................................................... 286 + 0.0 - 0.2 mm
Thickness ................................................................... 15.9 mm ± 0.2 mm
(Rate of change 0.03 mm in 30O rotation max.) ...... 0.05 mm
Minimum disc thickness, requiring replacement ........ 13.9 mm
REAR CALIPER
Type ......................................................................... Single piston, sliding caliper
Bore diameter (nominal)............................................. 40.5 mm
Rear Disc Pad
DRUM PARK BRAKE
Type ......................................................................... Banksia, single shoe, cable and lever operated
Drum
Inside Diameter (nominal)....................................... 190 mm
Maximum out of square (TIR with disc surface) ..... 0.05 mm
Maximum out of round ............................................ 0.08 mm
Linings
Type ........................................................................ Bonded
Width ....................................................................... 25 mm
Thickness ................................................................ 3.5 mm
Minimum Thickness before Replacement............... 1.5 mm
Burnout124
Western Australia
VY Executive S2/ VY SS 6sp
It all depends on how you drive you could probably get betwen 5-10,000 km . You may want replace them soon anyway to save leaving it to late and damaging the rotor.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
5mm should last at least 10,000kms with normal driving.
Just keep an eye on them.
neilrich
Rockingham
2003 VY commodore Lumina Wagon
torque wrench settings
Hi guys,
some great brake info there. I will be replacing the brake pads on my 2003 vy Lumina wagon soon and i am looking for bolt torque settings (if there are any) for the calipers etc.
Does anyone know what these settings are.
Thanks
Neil
Chrisvyss
02 VY SS
30-34 nm for the guide pin
80-90nm plus 40deg-50deg turn front calipe frame bolts
70-80nm rear caliper frame bolts
neilrich
Rockingham
Thanks Chrissvyss, much appreciated.
