Vy Calais l67 engine in a VS wagon
Copls1
VX SS
Hi I know it may have been asked before but I’m new to this what’s involved in putting a vy l67 motor into a VS commodore, I have everything vy l67 loom ecu, bcm ect, it’s it literally just plug abs play, any help would be appreciated.
Also my nephew has a vx l67 his wanting to put in his vy is this the same sort of deal ?
Phillbert
Gold Coast
VS L67 Ute, VX SS
Your answers are here in above link.
Might be easier to go with the VS wiring and extend it and get a L67 memcal for the VS....
L67 conversion into factory 4 speed auto commodore
  • If running the factory loom then several wires must be extended including:
  • Fuel injectors
  • Crank angle sensor
  • Temperature sensor
  • High flow fuel pump (walbro 255LPH EFP-057/GSS-342)
  • PCM/memcal must be recalibrated
  • Make sure you retain the L67 flexplate when purchasing the motor as the ecotec and L67 have dissimilar rotational harmonies
  • These following steps regarding wiring only apply if your undertaking a complete conversion (meaning Ecotec/Buick V6 and automatic transmission swapped with an L67 and manual transmission)
    - bridge neutral/park safety switch permanently for the car to start
    - wire up the manual speed sensor to the dash (3 wires)
    - wire the manual reverse switch to the reverse lights (2 wires)
_R_J_K_
Zenki S14
Just use all the VS electronics and get an L67 memcal, the VY ECU and BCM won't work in a VS.
