Vy clubsport
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Datgap, May 26, 2012.
  1. Datgap
    Datgap New Member
    perth
    vy clubsport
    My vy clubsport just hit 130,000km, so i was going to change the oil and filter, i was thinking of doing an engine oil flush using Liqui Moly engine detox, A few guys from work said its bad for my engine, but im not convinced anyone else use engine flushes without any problems?
  2. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    I tend to agree with your workmates.
    Unless you get every bit of the flushed oil and "debri" out of the sump there is a chance that something could float back into the oil pickup and clog it.
    Some of these flushing oils will remove varnish and debris that in a lot of cases would stay locked away in a corner of the block and never cause any problems.
    I have never done it and never had any problems with my cars which have and had oil changes every 5000klms.
    My VL turbo did 330,000klm with out any major internal work even the head never came off which was a common complaint when they lost coolant.
  3. HoldenMan7
    HoldenMan7 Member
    WA
    VZ SS 6 SPEED MANUAL
    Hey mate
    If you really wonna do a flush what i do is just put new oil and filter on run it for a few days and then just dump it and fill up again with fresh oil, though i wouldnt bother aye mate, if you change the oil every 5000 ks, you should be all good.......
  4. Sean880
    Sean880 Well-Known Member
    VIC / NSW
    2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
    Exactly correct. Flush it with fresh engine oil. Pretty simple really. Then its a matter of frequent oil and filter changes to keep it clean and maintain optimum lubrication.
