VY Clunky auto gearbox problem
pez1206
Perth, WA
Commodore VY 2002
Hey Guys,
Did quick search and found a bit of info but still not sure what the problem is.....
My 2002 vy commodore (210,000km) has a very clunky gearbox mostly in reverse and 1st (at low speeds) but also when changing up at speeds of around 70km-80km it also seems to clunk and hesitate until I gun it. Anyone familiar with this kind of issue?
The car still drives fine so if its no major issue I will leave it, but if its not very expensive to fix I will get it looked at.
someguy360
The Shed
Various
You will probably find it to be a bad Trans Mount, Worn uni joint/tail shaft coupling, center bearing, or rear drive shafts.
Mine has a clunk going into first and reverse, its play in the tailshaft not the transmission
